57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Installation problems with 2008
Fri, Nov 30, 2007 at 3:48:46 AM | Installation problems with 2008
Lestalt
Alright, I'm wondering if anyone else has had this problem.  I'm trying to install the student version of Revit 2008 on my laptop.  I get to the point where the content loader is trying to install some components, ie Weblibrary.cab, accurenderredist.cab, as well as 7 other ones and I keep getting this error: /download/2008/contentENU/ENUheld.cab could not be downloaded, the server replied with a 0, then it repeats the same thing for each of the 9 "content bundles" that are trying to be installed.  The program works, but I don't have some of the files that would be useful.  Any assistance would be awesome!  Thanks and have a goodnight,
Chris
Sat, Mar 22, 2008 at 2:16:51 AM | Installation problems with 2008
amitjersy
I have the same problem.
 Cabinet Files Installation Error while installing RAC 2008
After accepting License Agreement, When I press Install button to install the "Cabinets File" then "Content Extraction Dialog" reports the following errors abut errorneous cabinets, Pressing Skip or Retry doesnt solve error: -
Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\ENUHelp.cab"
When I press Skip, then other error appears: -  Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\IntMetTempl.cab"
When I cancel Cabient installation process then, a dialog appears that RAC 2008 is successfully installed but when I run the application then it give error that - "AccuRender rendering feature is not available because the Accurender library could not be found on your computer. Please check the AccuRender resource path set in settings> Option dialog"
After it another error appears that the default template file specified in the "File Location" section of the> Setting>Options Dialog (C:\Document & Settings\All User\Application Data\Autodesk\RAC 2008\Metric Templates\DefaultUs-Canada.rte) does not exist. Other error appearas that: - Some of the Revit Content that you chose to install was not successfuly installed, do You want to try and install the content again. When I press Yes to install the require content then the same error occur that: -
RAC is installed porperly but except the Templates & Cabinet files. I checked in RAC 2008> Settings>Options>File Location>Default Template File then Press Browse for looking of defaultUS-Canada.ret, But this template is not exist.Pls tell how to install cabients file without any error.
Installation Problems
Workflow & Implementation >> Chameleon
Mon, Jan 14, 2013 at 12:07:30 PM
Installation Of Revit Architecture 2009
Mon, May 5, 2008 at 1:59:54 AM
second nature installation
Thu, Feb 17, 2011 at 6:39:14 PM
REVIT 2008 - How to avoid Problems?
Sat, Mar 22, 2008 at 8:47:05 PM
Revit Architecture Update #1
Tue, Jul 24, 2012 at 5:39:15 PM
Page generation time: 0.8593
