47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Level Markers
18 Posts No Rating |
I have created an interior elevation view but the level symbols do not appear at all. I've search for them in the hidden view and they don't show there either. How do I mark every level without creating a new level? I have also tried to mark the levels by making a level marker from the drafting component and unchecking "Make plan view" but this does not create a functional marker. If someone knows how to do this, please let me know. I'm using revit 2008. Thanks
Do the level markers show up in other views? If so, you have probably moved the 3D extents of the level. If this is the case you will not be able to see those markers in any view that the 3D extents do not pass through. You can reset the 3d extents of a level by selecting the level, righ click and go to Maximize 3D Extents.
Adding Level Markers in Elevation |
Thu, Feb 16, 2006 at 12:55:41 PM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales |
Mon, Feb 20, 2012 at 11:33:58 AM
Level Markers have disappeared! |
Thu, Sep 11, 2008 at 9:51:12 AM
Eleveation Markers not showing in foor plan |
Fri, Aug 29, 2014 at 2:17:46 PM
Can't see level markers in section views |
Mon, Jul 16, 2012 at 11:05:34 AM
Members: | 2000497 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
