105 Users Online (104 Members):
Forums >> Revit Building >> Technical Support >> Embedded detail component scale issue
I've created a new component (tree I want to display in 3D model views) and inserted a detail component within the plan view (A more detailed plan). However when I insert the component into a project the detail component ends up to be five times the size it should be. All the other elements in the component are fine, I've checked project units and they all match. I'm stumped. Someone please help!
plant families symbols are the only ones that scale and they do so based on the height parameter of the tree. So what you want to do is to create a plant family with the symbols you want the nest that into a second plant family, then it will scale based on the tree ht. pretty cool actually, you can create some awesom tree using dwg elevation and plan symbols this way.
Excellent! Sorted thanks for the help.
Embedded Detail Component and Object Styles |
Fri, Feb 12, 2010 at 3:21:25 PM
embedded detail |
Wed, Jan 25, 2012 at 3:29:35 PM
Embedded Detail Shows in plan view, but not in the plan detail call out! |
Fri, Mar 4, 2011 at 1:37:23 PM
wood joist detail component issue |
Wed, Mar 29, 2017 at 9:50:12 AM
Nested Annotation Family in a Detail Component |
Fri, Mar 16, 2012 at 8:56:45 AM
Members: | 1999251 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
