45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Ceiling tag for exposed structure
Mon, Oct 8, 2007 at 10:23:40 AM | Ceiling tag for exposed structure
johnnyutah54
I am trying to get my rcp's working nicely and for the most part they are bomber.  I am trying to figure out how to place a ceiling tag in a room that technically has no ceiling so that it would show an exposed structure.  Would I need to just create a dummy tag to put in that room, or is there an easier way?
Mon, Oct 8, 2007 at 10:55:30 AM | Ceiling tag for exposed structure
laurabh
Since there is no ceiling, there's nothing for a tag to reference.  So, yes you have to create a dummy tag using a generic annotation.  I've attached one I've made if it helps.
Mon, Oct 8, 2007 at 11:05:47 AM | Ceiling tag for exposed structure
johnnyutah54
Thanks for the response.  I figured that was the case and I created a dummy tag similar to what you did.  When I create a generic annotation, however, it tells me that i need to set the family category to ceiling tag in this instance.  If/when I do that, how do I insert this dummy tag?   When I use the "tag" command, I need to select something to tag.  Or if I copy a tag and change it to the generic, it is still associated with the other ceiling.  How does that work?
Mon, Oct 8, 2007 at 11:13:27 AM | Ceiling tag for exposed structure
laurabh
Since you're technically not tagging anything, the tag command won't work.  Instead, under the Drafting Tab, click on Symbol and select the fake ceiling tag from the Type Selector pulldown and insert.
ceiling plan - exposed structure
Mon, Sep 29, 2008 at 11:28:23 PM
Exposed Structural Floor Ceiling Plan
Thu, Mar 21, 2013 at 8:30:25 AM
exposed ceiling
Tue, Jun 16, 2009 at 12:37:25 AM
Lighting on Exposed Stucture
Mon, Feb 21, 2005 at 11:31:32 AM
Exposed Roof Deck_Tag with Height
Tue, May 31, 2016 at 3:59:37 PM
Page generation time: 1.2069
