44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Upper level floor Depressed Concrete Slab
Fri, Oct 5, 2007 at 12:08:47 PM | Upper level floor Depressed Concrete Slab
wiredguitarist
Hello all,
 I am attempting to create a depressed concrete slab in a composite steel deck.  I have attached a picture of my desired output and what I have in Revit so far.  I have attempted using the edit edges tool but I always get extra lines in places where I don't want them.  If anyone knows of a tutorial for drawing details mostly for Structural dicipline it would be appreciated.
Thank You
Sun, Oct 7, 2007 at 9:48:52 AM | Upper level floor Depressed Concrete Slab
3.5 Stars: 395 Votes
I would probably do this as two slabs.  One with a hole in it.  Because the top of the lower slab is lower than the bottom of the top slab, I would propably use a edge sweep here to join the two then use join geometry to clean it all up.
Seems kind of messy - maybe someone else has another idea.
Why is floor slab edge below showing through on upper level plans???
Fri, Mar 26, 2010 at 3:56:22 PM
Floor Slab Slope
Tue, Jan 30, 2007 at 11:01:08 AM
Concrete Beam and Slab
Mon, Jun 3, 2013 at 2:47:31 PM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Metal decks spanning in different directions on the same level
Mon, Nov 9, 2009 at 7:52:16 PM
Page generation time: 2.9003
