65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roof not showing up when exported into SketchUp?
Fri, Sep 28, 2007 at 3:11:02 PM | Roof not showing up when exported into SketchUp?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok I've done it before and it worked.  I have exported a .dwg from Revit and imported into SketchUp.  Now I'm on a new project and when I import into SketchUp my roofs show no material in places.  The weird thing is it seems like it's trying but nothing is there so I can see the inside of my project.  Does anyone know why this is?  Thanks,
Lorne
PS-I attached an image of the issue.
Denver, CO
Revit Architecture
Fri, Sep 28, 2007 at 3:13:56 PM | Roof not showing up when exported into SketchUp?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Oh and I'm using Revit 9.1
Denver, CO
Revit Architecture
Tue, Oct 2, 2007 at 9:24:40 AM | Roof not showing up when exported into SketchUp?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
anyone???  I really need to get this figured out.  If I export my model as a .dwg (the same way I am doing for Sketchup) and open in AutoCAD it is a solid roof.  There is something with sketch-up that is weird about it.
Ideas?  Please?
Denver, CO
Revit Architecture
Fri, Oct 5, 2007 at 8:40:50 AM | Roof not showing up when exported into SketchUp?
Hence
1 Stars: 1 Votes
i don't know if it is too late, but the only thing i can think of is just redraw the roof in sketchUp.  There is something wrong with the way revit talks to sketchUp.
Fri, Oct 5, 2007 at 9:10:35 AM | Roof not showing up when exported into SketchUp?
Sk8punk
maybe you should go through the element properties im in 10th grade but i know most of the things on revit
when exporting from sketchup to revit - urgent problem!
Wed, Mar 9, 2011 at 8:25:46 AM
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Selective 3d Exporting
Wed, Feb 11, 2009 at 7:25:58 PM
Trouble with the Curve (Roof that is)
Tue, Aug 5, 2014 at 9:24:32 AM
Page generation time: 0.6341
