46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Revision Letter instead of Number
Thu, Sep 20, 2007 at 2:34:01 AM | Revision Letter instead of Number
Mentos
Is it possible to use revision letters instead of numbers? Weare using Revit Structure 2008. I have found some workarounds for this problem on this forum, but they are dated back to 2005-2006. I was looking for something newer.
Thu, Sep 20, 2007 at 12:48:35 PM | Revision Letter instead of Number
justinblack
The answer is still no.  We too use Letters and not numbers so we've resorted to workarounds!
JB
Sun, Sep 23, 2007 at 3:13:29 PM | Revision Letter instead of Number
anthonyforlong
Hi,
Check out www.revittv.com, this third part software will automatically create your drawing sheets and manage your revisions for you!CheersAnthony
Wed, Dec 12, 2007 at 10:36:31 AM | Revision Letter instead of Number
jlatour
The only thing that I've found that works is to include the "Issued To" category in the Revision Schedule on the titleblock.  This is a field that is available in the Revisions dialogue and it's not restricted to numeric entries.  This may be the work around you were talking about but I just thought I'd throw it there for future searchers.
 The problem with this begins when you have a common template for the whole company since some people are better with Revit than others and you have to make sure everyone is aware of the cheat method.
 Somewhere in the program files, there must be a master shared parameter file that could be added to to include a revision letter parameter.  Although, when editing the revision schedule in the titleblock it doesn't give the option to add a parameter.  Anyone have any ideas?
Wed, Dec 12, 2007 at 10:36:41 AM | Revision Letter instead of Number
jlatour
Wed, May 7, 2008 at 5:12:23 PM | Revision Letter instead of Number
RLAKES
It looks like 2009 has an Alphabetic option.
How do you add a revision letter in front of the revision number?
Mon, Oct 19, 2015 at 7:35:10 AM
Revision Number for sheet issued for the first time [ 1 2 ]
Tue, Oct 15, 2013 at 10:05:01 AM
19
Linking revision number to sheet number
Mon, Sep 20, 2010 at 1:50:30 PM
revision number in titleblock
Tue, Dec 5, 2006 at 10:04:31 PM
To set up Revision cloud schedule, and add prefix to Revision Number?
Sun, Jul 19, 2020 at 6:35:17 PM
Page generation time: 2.2022
