142 Users Online (140 Members):
Forums >> Community >> The Studio >> New build of 7.0 (20050126) is on the web
8 Posts No Rating |
All,
A new build of Revit 7.0 has been posted to the Download Center. This build is more recent than the one subscription clients received in the mail and addresses some specific items, including:
o Filled region in drafting view masks titleblock
o 3D extents of Levels and Grids are better preserved during file upgrade
o Generic models do not appear in plan views after 7.0 upgrade
o Performance improvements with grid and level heads
o Linked .dgn files will not reload if unloaded
o Dimensions of imported dwgs are "cleaner"
o "Zoom to Fit" no longer zooms too far out
o Curtain wall/grid improvements
If you are not experiencing these issues there is no need to upgrade to the latest build on the web. If you have not installed 7.0 and have a decent internet connection, it may be worth while to download and install this build when you are ready to deploy.
2 Posts No Rating |
There is a newer build - 20050201_2130 on the web now, do you know what new fixes this has, it seems an awful lot more stable, perhaps they've fixed all those memory leak problems?
The only differences between these builds as i've been made aware is the latest build has support for multi-languages...
ummm...
Which download section on revitcity or augi or autodesk?
I cannot find the link.
2 Posts No Rating |
http://revit.autodesk.com/7.0/common/download.asp?en-us
New build of 7.0 (20041213) is on the web |
Tue, Dec 21, 2004 at 4:41:51 PM
New build of 7.0 (20041113) is on the web |
Mon, Nov 15, 2004 at 4:42:37 PM
Updated build of Revit 6.1 (20040720_2100 ) available on the web |
Fri, Jul 23, 2004 at 1:26:56 PM
Latest Build of 6.0 |
Sat, Feb 21, 2004 at 10:58:20 PM
Revit 2009 Web Library |
Wed, May 21, 2008 at 4:13:53 PM
Members: | 2001032 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
