65 Users Online (64 Members):
Forums >> Revit Structure >> Technical Support >> Can't import dwg or dxf to RS2008
8 Posts No Rating |
Has anyone else had the problem that you can't import dwg or dxf into RS2008. The dwg imported ok into RS4. Since upgrading to RS2008, can't import any dwg or dxf into the project. Have tried uninstalling and re-installing. Tried uninstalling and install latest build version. Nothing seems to work. RS2008 installed using a network deployment & none of the computers unsing that deployment can import dwg or dxf. Anyone have any suggestions or solutions. Coming to my witts end as I have drawings to issue using these files.
8 Posts No Rating |
We found the answer to the problem. So for those who maybe or might have this problem of importing dwg or dxf files into revit structure. You need to uninstall the version of DWG Trueview and install the most current version, or uninstall it completely. I believe that Autodesk will release a patch for this soon!!
import 3D model in DXF or DWG - how use it? |
Mon, Oct 31, 2005 at 9:28:45 AM
Problems importing .dwg or .dxf................................. |
Mon, Feb 25, 2008 at 11:12:13 AM
DWG/DXF layers. |
Wed, May 31, 2017 at 7:05:57 AM
Mass won't export/import |
Sun, Jul 23, 2006 at 2:34:08 AM
Are there any dwg /dxf files to download, all I see is *.rfa |
Thu, Feb 5, 2009 at 10:12:18 AM
Members: | 2000355 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
