74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Different Scales Using Dependent Views
I'm using Revit 2008. I have been waiting for the Dependent View Feature though I have a questions. Is there a way to show the entire building at 1/8" scale and the independent views at 3/32". It seams once you change the scale in the parent or dependent view, it changes it everywhere. Is there a way around this?
you cannot have a dependent view be in a different scale than the original view. as to whether or not there is a work around i do not know HTH
Edited on: Sun, May 20, 2007 at 6:42:15 AM
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
Detail Callout Bubbles and Dependent Views |
Thu, Aug 12, 2010 at 6:51:10 AM
Design options and dependent views? |
Wed, Nov 4, 2009 at 8:26:39 AM
filled region in dependent views |
Fri, Feb 22, 2008 at 6:53:39 AM
Collaboration and dependent views |
Fri, Jun 9, 2017 at 10:14:43 AM
Members: | 1999281 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
