63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> creating mass through solid sweep
hi I'm working at a project involving a complex steel structure roof.I need to create a mass using a spline profile and also a circular section. I wanted to do that using the solid sweep command but apparently I can't have both a curved path and circular section. The compromise was to use a curved path and for the section to use a polygon having as many sides as possible . I don-t really like that though....because if I look at the structure closer i can see the edges. If anyone has any ideea about how cand i do this please help me
Can you post an image of what you are after? Remember that creating masses is not only an additive but also a subtractive process. Starting with a positive mass and subracting from it with voids is the best way to create complex shapes.
Tom www.reviteer.com http://twitter.com/Reviteer |
I concidered using the void command...but i think it's even more difficult to do that.the most convenient way would be to create a sweep with a curved profile and a circular section.looking forward for suggestions or advices. the photo I've attached is of a structure (the international airport in osaka ) I've found over the internet but I think it gives a good example for the kind of structure I'm trying to create.
You can do a circular sweep on a curved path, not sure about splines though. A trick I learned from James V. at SOM they used on the Freedom Tower was to apply sweeps to edges of a void. I've attached a quick example of this method for you to reverse engineer. The voids can be parametric as well giving you real power to possibly build what you are attempting.
unfortunately I wasn't able to open the file as I am working in an older version of revit. I've attached a photo with what I've come with so far.As I will surely have to make many changes on the project I'll try to take your advice. The mass created so far was through sweep with curved path and polygon/circle profile . Thanx so much for advices
Autocad 2011 Solid To Revit 2011 Mass floor error |
Mon, Feb 28, 2011 at 7:20:10 AM
Solid Sweep and doors? |
Thu, Apr 27, 2006 at 10:59:11 PM
Creating a solid mass from a toposurface |
Wed, Mar 21, 2012 at 3:37:32 PM
creating a solid that changes in height and width. Sweep will not work. |
Tue, Apr 6, 2010 at 10:32:49 AM
creating a solid mass geaometry |
Fri, Nov 4, 2011 at 6:42:50 AM
Members: | 2000426 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
