78 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Can you convert model lines to detail lines?
5 Posts No Rating |
When you import details (ie. a window head detail from a manufacturers site) (dwg files) the lines come in as model lines. If I wanted to add the drafted detailing to a wall section, for example, is it possible to convert the lines to detail lines to do so. Model lines are not compactible with views such as sections. It seems absurd to have to trace over model lines with detail lines when everything is already drawn for me. Can anyone help?
Post edited on 2004-12-22 16:13:45
Make sure current view only is ticked when importing the dwg. This will effectively make them detail lines when the dwg is exploded.
1 Posts No Rating |
Excellent Mr. Spot! But, Is there a tip to import the dwg as symbolic lines? I mean, I have the same problem as smh, but I need the drawing in symbolic lines... Maybe a tip to convert them? whatever!!! That will be very usefull to recycle the old CAD library with tree blocks and vehicles.
78 Posts No Rating |
Revit 2010 subscription advantage pack has the ability to convert lines from model to detail (or symbolic). Revit 2011 will have this feature upon release. Although, I should not, it is slow as heck!
This was new in 2010 I think. Converting Line Types in your HELP
Can I convert detail lines to model lines |
Tue, Jul 29, 2008 at 3:03:49 AM
MODEL LINES VS DETAIL LINES |
Mon, Jul 10, 2006 at 9:11:05 PM
Model Lines to Detail Lines??? |
Sun, Aug 31, 2008 at 9:24:50 PM
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
Convert Lines |
Tue, Jan 25, 2011 at 5:03:38 PM
Members: | 1999800 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
