66 Users Online (68 Members):
Forums >> Revit Building >> Tips & Tricks >> white lines
16 Posts No Rating |
How do I make a white line? I'm trying to cover up a line in plan that I don't want to show up.
I don't even want to know what you are covering up... You can use a filled region with a white fill and use the invisable line type to make the region. As a side not I'm sure there is a better way to do what ever it is...
----------------------------------- BallewDesigns.com |
3 Posts No Rating |
what type of line are you trying to cover? where is it showing up at? try clicking the "linework" icon on your toolbar and select (invisible lines) in your "type selector" pull down menu. Pan over the line you want and select. use the same process and select (by category) to bring the line back. Edited on: Mon, Mar 19, 2007 at 11:17:54 AMEdited on: Mon, Mar 19, 2007 at 11:21:44 AM
Edited on: Mon, Mar 19, 2007 at 11:26:06 AM
Thanks to both of you. Both suggestions will really come in handy!
White lines in section views |
Mon, Jan 22, 2018 at 3:14:15 PM
elevation lines obscuring everything else (revit 2015) |
Tue, Apr 14, 2015 at 2:05:53 PM
View image color |
Tue, Aug 25, 2009 at 4:02:38 PM
Converting things to white |
Thu, Dec 5, 2019 at 9:47:09 AM
White walls are dark grey when rendered? |
Wed, Aug 10, 2005 at 10:57:54 PM
Members: | 1999786 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
