62 Users Online (61 Members):
Forums >> Revit Systems >> Technical Support >> window tags in elevation
17 Posts No Rating |
window tags dont appear in elevation view, even though "window tags" are checked ON in VG visibility graphics ??
This is just a guess, but did you add one or two windows and then copy then. If you did the tag will not show up. Go Drafting - Tag - By Category and click on your windows. Do you see and tag on any of the windows in elevation? Can you add tags.......Go Drafting - Tag - By Category and click on your windows.......what happens?
You can also go to the DraftingTAB and use the 'tag all not tagged' command and choose Widnow tags to tag them all in one fell swoop.
thanks. the tags not all tagged command, though it has a funny name is altogether wonderful! Still have a an issue, though. I created a big house out of a few pavillions linked together. Inside the link, such as Garage Pavilion, i have now been successful at displaying the window and door tags on the elevations, but when i go to my overall pasted up composition, the tags do not appear, nor can i make them appear by tagging. any advice?
admin
You can't tag elements that are in a linked file. You can, however, display the annotations from a particular view in the linked file. To do so go to visibility/graphics and select the Revit Links tab. Select the "By Host View" button next to the appropriate link. Once the dialog opens, select "By Linked View" and select the view that you want to display from the linked file. See the attached images.
Edited on: Wed, Feb 7, 2007 at 9:56:28 PM
Hiroshi Jacobs
The Catholic University of America |
Hiroshi, The 'by linked view' in elevations is greyed out as an option. Even setting to custom and turing on the annotation doesn't make the tags in the linked file visible. Works fine in floor plan views though.
yes, thanks. i did find the grayed out option when i followed that path. yes the plans work ok cause you can manipualate the settign to by linked view. any way to get around this. I cant seem to even manually place a window tag in the linked file
Door and Window Tags in elevation |
Tue, Apr 18, 2006 at 10:55:17 AM
Window Tags not working |
Fri, Sep 24, 2010 at 7:30:45 PM
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags |
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags |
Thu, Mar 17, 2011 at 5:09:02 AM
Members: | 1999844 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
