52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall Clean
Wed, Jan 3, 2007 at 7:52:37 AM | Wall Clean
vrmoreno3
I have a brick and cmu wall. The brick is unlocked with a base offset. The walls that abutt the brick side stop short of the cmu, but at the face of brick (which is up high), so there is a gap. How do I get the wall to clean?
Wed, Jan 3, 2007 at 3:19:55 PM | Wall Clean
rkitect
rkitect Avatar
4 Stars: 29 Votes
I assume you mean like the first image attachment.
If so, I've done this seen a couple different ways.
1) Make a reveal in the bottom wall for the brick ledge and use the attach command to attach the wall to the bottom of the floor of the level the brick/cmu wall is on.  This was done to achieve the detail shown here.
2) Make a wall type with two layers of the same material.  Make the exterior-most layer the same width as your brick + air cavity.  Unlock that layer and bring it down to match the brick layer.  Attaching the wall to the floor level that brick/cmu wall is on should take the rest of the wall all the way up.  I tried this but it leaves a nasty line between the two layers that can be fixed with the lineworks tool.  However, there were other visibility issues I ended up with so I used the first option above.
HTH
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:25 AM
Wall clean-up
Fri, Nov 21, 2008 at 3:21:13 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:49 AM
11
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:10 AM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:20 PM
Page generation time: 0.6912
