Forums >> Revit Building >> Tips & Tricks >> Leaning Columns
4 Posts No Rating |
I have been looking for a way of rotating a circular column in Revit 6.1 to no avail........ ?
3 Posts No Rating |
Try looking sideways Andrew
3 Posts No Rating |
maybe try drawing line at angle in elevation and then extruding colomn to that angle
4 Posts No Rating |
I found the way to do it by creating a family with extruded circle along a path. The path has the angle that is parametric along with the length. Currently looking for a way to make the circle radius parametric..........
Ive made a similar type of column, however its rectangular. Created through a blend when you can specify the angle as well as the rectangle size. Let me know if you want to take a look as i'm sure you could edit it to have a circle in stead... Even have it taper if you like?
4 Posts No Rating |
Is mr. spot jothan briggs other name?
Yes that would be good to look at your rectangular column thanks
Wes
No? What gave you that idea...?
Any way here's the file.
4 Posts No Rating |
thanks Mr. Spot
I've attached one I had done earlier for Dps. It may be of use but you probably already got one.
14 Posts No Rating |
Mr. Spot, could you post the column that you have that tapers as well as leans? I am looking for a tapered beam and thought I could apply what you have done with the tapered and leaning column.
0 Posts No Rating |
I understand there is a certain parameters that you could add up and matches to the length, howver,, you just need to work around on that to get the matchup.
http://caldwells.com/
2070 Newcomb Avenue,
Unit B, San Francisco,
CA 94124 |
richcollin,
I see that you just joined today and you have made two posts - both don't seem to make much sense.
You did notice that this thread was last posted in 2006?
Are you just bored?
