66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Ceiling Views not showing
Hi
Has any one had any problems with their ceiling veiws not showing? I have the rooms drawn up and it should appear as an underlay in the ceiling plan but absolutley nothing is appearing in Ceilng Views 1 or 2.
Kirk
1 Posts No Rating |
I have the same problem only the ceiling plan was there, I put in lights, did some rendering exercises to confirm the locations are what I wanted then the plan vanished. The ceiling is still there but I cannot get it to view on the ceiling plan. I can modify it in the floor plan if I select it in section then edit in plan but nothing shows up in the ceiling plan. I have opened the file using the audit function and that has not corrected the problem. Any suggestions? Version 9.1
In that Ceiling plan, if you use the TAB key near the limits of the ceiling you can selected, you are using a "Plain" ceiling with out a "Pattern" right?
Floor and Ceiling Surface Pattern not showing in some 3D views |
Tue, Apr 11, 2017 at 6:55:32 AM
CEILING NOT SHOWING |
Thu, Oct 30, 2008 at 11:35:13 AM
Section not showing ceiling |
Fri, Jun 14, 2013 at 11:17:08 AM
ceiling plan, light fixture not showing |
Sun, May 24, 2015 at 5:05:30 PM
Ceiling Level Keeps Showing up |
Sat, May 29, 2004 at 10:33:13 AM
Members: | 2000371 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
