115 Users Online (114 Members):
Forums >> Revit Building >> Technical Support >> Help me to create Lintel Beams
7 Posts No Rating |
In India, normally we do the Load Bearing Structure of small Residential buildings, in that building we use to do the Continous Lintel at 7'0" level in above Brickwork. Now i m facing problem how can i create the Lintel Beams and How can i create 2'0" wide Sunshade above windows & openings.
Vijayakumar |
11 Posts No Rating |
You can customise your window families to include a lintel beam although you possibly can't schedule it. Normally you shouldn't over complicate the Revit Project file, try to get away from creating too many necessary 3D object that you wouldn't see. Lintel for example is what I would classify as neccessary becasue you can shown the lintel in a detail drafting view or section view add a 2D detail component. Otherwise you'll end up with big file.
You can create a window shade using metric generic model wall base. It'll snap the object to a wall.
How do i Create Lintel Beams ? either Continous or Cut Lintels ? |
Tue, Sep 12, 2006 at 9:52:25 AM
Lintel Symbols NOT to show in Lintel Schedule |
Thu, Mar 15, 2012 at 2:40:51 PM
How to create a lintel |
Mon, May 14, 2007 at 4:43:17 PM
Lintel Shedual |
Thu, Sep 30, 2004 at 5:13:41 PM
Arched wall lintel over an window |
Sat, Jan 10, 2015 at 1:38:47 AM
Members: | 2000964 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
