124 Users Online (123 Members):
Forums >> Revit Building >> Technical Support >> How can i mirror the entire model ?
7 Posts No Rating |
Hi all,
I created one complete model for G+60 Rectangular tower including internal and external details. Now i need to mirror the entire model, b'cos there will two same type towers. Now i need to know how i can mirror the first tower exactly opposite with all model and other details.
Vijayakumar |
58 Posts No Rating |
try grouping the entire model and mirroring it...most of the components will mirror, mayb some elements like roof fascia and such hosted elements may have to be redone.
but mirroring can be done.i have done some time back..just that i dont recall the details.
24 Posts No Rating |
Try opening a blank document (Document A). Close the “G+60 Rectangular tower” file (document B) and import it into the Document A. Then Mirror/copy.
Should there be any changes to the building, open the original “G+60 Rectangular tower” (Document B) and edit it accordingly. Once this original is saved it will automatically update both the towers in Document A and save you form doing work twice.
Hope this helps.
Thanks for this post! I was searching an easier way to mirror an entire project and had never thought of linking into another revit file. What I ended up doing was linking the file in, Mirroring it, and binding because I need a right and left orientation but the left has a slightly different arrangement than the right. Thanks again.
Move half of entire project down vertically |
Tue, Aug 4, 2015 at 10:35:42 AM
MIRROR entire HOUSE |
Thu, Feb 12, 2009 at 6:23:19 AM
Mirroring entire plan? |
Wed, May 4, 2011 at 11:55:15 PM
using the mirror comand [ 1 2 ] |
Thu, Oct 15, 2009 at 9:13:36 AM
17
HELP... need to mirror a plan |
Wed, Jul 2, 2008 at 12:27:55 PM
12
Members: | 2000918 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
