59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Visibility Parameter in Room Tag
Wed, Jul 26, 2006 at 5:58:56 PM | Visibility Parameter in Room Tag
NewtoRevit
Hi everyone, I am new to revit and this forum rocks!! I have a question regarding Room tags and not sure if this can be done, Is it possible to add a visibility instance (yes/no) parameter to a room tag such that one can turn off the lines(rectangular box) around the room number (Just like the parameters: Show room number and Show room name)? Because if I uncheck show room number, then the boundary/rectangle still remains which doesn't look good in plans. I went through the family creation tutorials and have been trying to do this for a while now but not able to achieve what I am looking for, Any help is greatly appreciated, Thanks So much!
Wed, Jul 26, 2006 at 9:28:51 PM | RE: Visibility Parameter in Room Tag
TomDorner
4.5 Stars: 25 Votes
Yes you can add a visability parameter. When you click on the line(s) go to properties and you will see an '=' sign. Click on the = and add a new visability parameter. I've attached an example for yu to reverse engineer. You could also take a different approach. Simply define a room tag without the lines and load it into your project. Then in a view or global basis select all the room tags and change them to the type you want. HINT: right click on a room tag and choose "select all instances" this will select every room tag of a similar type in all views. You can also select everything in a view and fitler out to only room tags. HTH Tom
Thu, Jul 27, 2006 at 3:07:52 PM | RE: Visibility Parameter in Room Tag
NewtoRevit
Thank you sooooooo very much!!!
Fri, Aug 22, 2008 at 5:16:37 PM | Visibility Parameter in Room Tag
dude99
Can you have a instance parameter in a room tag?  It seems when its a instance param its not available, only type params are available.
Thu, Jun 3, 2010 at 9:15:55 PM | Visibility Parameter in Room Tag
mudan
hi guys i got a stupid box in my room tag. when i go into family its not there but when i load in to project,there it is! can anyone tell me whats wrong with my tag? also if i draw a line in my room tag family its come up with a warming saying not visible and ,same problem, when i load into drawing, she will show upSad
Fri, Jun 4, 2010 at 7:10:43 AM | Visibility Parameter in Room Tag
Open the family up to edit and look at your VG settings.  Make sure to click the "show..." and you will see the box.
Fri, Jun 4, 2010 at 6:01:10 PM | Visibility Parameter in Room Tag
mudan
thanks heaps!
Visibility elements in a room tag
Mon, Aug 9, 2010 at 2:58:34 PM
URL parameter in a room tag
Thu, Feb 18, 2010 at 3:55:56 AM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:41 AM
room temperature parameter in room tag???
Wed, Oct 27, 2010 at 3:38:09 PM
Using a Yes/No Parameter to control the visibility of another Label in a Tag
Wed, Feb 6, 2013 at 2:03:22 PM
Page generation time: 0.7755
