77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exporting into AutoCad via e-mail
Mon, Sep 27, 2004 at 9:37:02 AM | Exporting into AutoCad via e-mail
byarchitec
How do I send Revit drawings as e-mails to AutoCad 2000 - 2004 users?
Tue, Sep 28, 2004 at 12:47:01 AM | RE: Exporting into AutoCad via e-mail
papurajx
Export the relevent 'Revit view' say 'Level 1 plan' for E.g into AutoCAD using the export command under 'File' Menu and send it across through e-mail....That's it.
Tue, Sep 28, 2004 at 9:56:33 AM | RE: Exporting into AutoCad via e-mail
byarchitec
Papurajx, I have tried this before. When you choose the Revit View (not sheet?) it asks you under File- Export-to choose "Dwg, DXF, DGN" then I save it to a folder. When I mail this new .dwg the reciever says that it has arrived missing it's ex-ref. Paul B
Tue, Sep 28, 2004 at 6:02:04 PM | RE: Exporting into AutoCad via e-mail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We always open the dwg file after the export and bind the xref's. By default revit has the sheet as one file and each addtional view a separate file xref'd into the sheet file...
Tue, Sep 28, 2004 at 8:45:16 PM | RE: Exporting into AutoCad via e-mail
byarchitec
Mr. Spot, How does one "bind" an ex ref? Paul
Tue, Sep 28, 2004 at 11:07:35 PM | RE: Exporting into AutoCad via e-mail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Open the dwg, sheet file. type "xref" then hit enter. Select all the xref's and choose bind, then you are given an option to bind or insert, choose bind... There you go (save). You can now delete the other dwg files that revit created.
Wed, Sep 29, 2004 at 10:13:24 AM | RE: Exporting into AutoCad via e-mail
byarchitec
Mr. Spot, Thank you for your last advise. But I cannot bind the new dwg. I take the Revit file choose export rename it and select view/sheet (which I check the appropriate one. I then open 1 of the new dwg's that have been created. I type in xref and once I am in xref manager there is nothing to select. I am given no files or xrefs to choose in the xref manager window so nothing can be bound. Do you have any ideas? Paul
Thu, Sep 30, 2004 at 9:39:52 AM | RE: Exporting into AutoCad via e-mail
byarchitec
Mr. Spot, Is my problem w/ the method of exporting? Have I corrctly formatted my Revit file before export? Paul
Thu, Sep 30, 2004 at 5:10:09 PM | RE: Exporting into AutoCad via e-mail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No your method is fine. Your opening the wrong file. You need to open the sheet file, you can tell my the size of the file also, sheet files will be typically around 40-50K where is the others will be inexcess of 500KB. Make sure you open the sheet file then type xref and bind...
Sat, Oct 2, 2004 at 12:44:57 AM | RE: Exporting into AutoCad via e-mail
byarchitec
Mr. Spot, Thank you it seems to have solved the problem! Paul
Trouble w/ exporting to AutoCad
Thu, Jan 20, 2011 at 11:18:07 AM
Thu, Jun 20, 2013 at 1:24:08 PM
Exporting Layouts in to AutoCAD / piping issue...
Thu, Sep 4, 2008 at 4:12:10 PM
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
Tue, Jan 30, 2007 at 11:32:22 AM
Page generation time: 0.4340
