140 Users Online (138 Members):
Forums >> Revit Building >> Technical Support >> Beam questions
1 Posts No Rating |
Hi guys I'm new here but i find this forum to be so interesting that's why y signed up. I hope I can be helpful some time too!
OK. here is my issue.
I need to know if there is any way I can change the shape of a beam end. I need to use a profile with angles and arcs.
On the other hand I need a clean intersection of two beams with oposite slopes. How do I do that?
Thank you very much.
3 Posts No Rating |
CG, i'm pretty new to Revit myself but from what i understand
so far, to answer your 2nd question, if you're using structural
beams then there is no "real" way to clean-up the intersection.
You can use "linework" and together with the "invisible" line
tool (& the others) you can clean it up that way.
Someone with more experience may be able to confirm (or trash)
my answer here.
11 Posts No Rating |
Open the 'Beam' family in the family editor and add 'Void/solid' to change the shape of the beam ends.
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
beam - how to show overhead? single line |
Wed, Jun 10, 2015 at 9:52:25 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection |
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
Members: | 2001032 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
