126 Users Online (125 Members):
Forums >> Revit Building >> Technical Support >> construct free forms
1 Posts No Rating |
when I make a mass then convert it to shell if the surface not horzintal or vertical it coverts to green surface which has not a family type and I want to convert it to roof or wall and use it in construction is there any way to convert irrigular surfane in to roof or wall?????
11 Posts No Rating |
Can you post a 'picture' of the Massing you are trying to acheive?
Massing shapes correspond to components as follows:
Vertical faces, including horizontal arc shapes, become walls. For more information about walls, see Exterior/Interior Walls .
Horizontal planes lying at the base of each level of the shape become floors. For more information about floors, see Adding Floors .
All other horizontal planes become footprint roofs. For more information about roofs, see Roofs .
All other faces, such as slanted planes or curved surfaces, become in-place roofs.
Components created by massing are locked to the massing by default.
I hope for tutorials on curved forms |
Fri, May 14, 2004 at 4:09:16 PM
Need forms for a residential environment. |
Thu, Mar 8, 2012 at 7:13:25 AM
Trouble with void forms and parametrics in families |
Mon, Jul 4, 2011 at 9:28:29 AM
Void Forms cut Revolve not successful and remove the line |
Fri, Mar 11, 2016 at 8:03:37 AM
Complex forms/Revit capability |
Wed, Jan 3, 2018 at 10:14:33 PM
Members: | 2001079 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
