120 Users Online (119 Members):
Forums >> Revit Building >> Technical Support >> small dimension box & tape measure dimension
8 Posts No Rating |
my dimension boxes & tape measure dimensions are quite small & keep scale ratio as I zoom in ,don't get bigger,must be a scale setting somewhere! I've been looking but
cannot find it. HELP.
11 Posts No Rating |
Change the 'View Scale' in the View properties..and try again..you might see them bigger.
6 Posts No Rating |
I just fixed that problem with my program today! You must go into your Revit.ini file. Double-click on it and it should open in notebook. Find the [graphics] line. (if there is not one, then type one in). Underneath that line you need to type,"TempDimFontSizeInPoints=24" The number refers to the size of the text. 24 works for me, but I have a 42" screen. Maybe try 16 becuase Revit starts in 8. Save the file and then restart Revit. I actually have two revit,ini files and I had typed that in both. That worked for me. I have a question in return: My tape mesure diminsions are set to 1/256 and are so all dimension attributes. How can I change them to 1/16 or 1/8? My project units are already set to 1/16 and it seems to do nothing for this problem. I have been looking all over help and all over AUGI, Autodesk, RevitCity and such like and have not found a solution. I would really help my tim in reducing fractions that we never deal with in real life. Thanks
Tape Measure Properties [ 1 2 ] |
Thu, Aug 21, 2014 at 12:15:12 PM
18
Listening dimension display too small |
Sun, Jan 31, 2010 at 6:43:41 AM
tape measure tool doesnt work in elevation |
Wed, Jan 12, 2011 at 1:19:04 PM
Removing/editing single dimension in dimension string |
Wed, Aug 26, 2009 at 7:12:02 AM
Model Dimension |
Fri, Feb 13, 2009 at 9:54:13 AM
Members: | 2001100 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
