56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit 2023 Crashes Every 5 minutes or less
Tue, Dec 26, 2023 at 1:36:12 PM | Revit 2023 Crashes Every 5 minutes or less
Mahmood88
Hi,
I'm working on ~40mb rvt file in Revit 2023 for 2 months with no crashes at all, they started to happen may be after I inserted a SAT file from Rhino 7 several times (once as a family, once as generic model, once as a mass and currently using the last one). The brought file is a simplified surface, no complication or large file here.
The crash happens after almost everything, no specific pattern for the reason behind the crash. Sometimes happens even after just opening the file without even touching a thing!
I am the only user, so not a shared file. However, the crash also happened while working on another project (~200mb no rhino files here), but it didn't happen when I worked on new project (I opened a new blank file, built some walls/windows/doors, etc. nothing happened).
I didn't try working on it from a different computer, but I tried to troubleshoot it like removing old corrupted links, removed some unupdated add-ons, but the crash still happens.
I looke up the Journal files, but didn't know what to look for, they said look for patterns, but even the short journal files didn't make sence to me
My computer is a workstation with good specifications, and the project was working for 2 months just fine
CPU core i9-13
Ram 64 GB
GPU NVIDIA Quadro T1000
1 TB SSD for the C folder 60% is free space
Window 11 Pro
Any suggestions?
Remove the number of back up files in revit 2023
Wed, Oct 25, 2023 at 9:56:28 PM
Revit 2023 - Can't Link Revit Models From Autodesk Construction Cloud
Fri, May 5, 2023 at 12:09:54 PM
Revit 2023 Un-Lock a Viewport
Tue, Dec 6, 2022 at 8:47:30 AM
Revit crashes when placing keynote legend
Tue, Jul 25, 2017 at 2:07:43 PM
revit crashes when adding picture to page setup
Wed, Apr 28, 2010 at 2:37:21 PM
Page generation time: 2.0810
