145 Users Online (144 Members):
Forums >> Revit Building >> Technical Support >> Export a CSV file (X,Y,Z coordinated) for a toposurface from Revit?
Revit ver. 2023.
I've always imported CSV files from Land-surveyors to create accurate toposurfaces; but this time a land-surveyor needs a CSV file from me, as I've modified his toposurface to suit my project.
It seems Revit can only export a CSV file from schedules. Does anyone know if it's possible to export a site / toposurface as a CSV points file (with the X,Y & Z coordinates)? Or perhaps if it's possible to create a schedule with a list of all points, to export as a CSV file?
Thanks in advance!
I have some things to think about but can not test ideas.
Note that all topo drawings are created from interpolated points. The triangulation edges for "Toposurfaces" are turned off by default. If you turn those off, you will see the points created by Revit to create their topo lines. But do you want to use those points?
For ease of surveying, the surveyor divdes the site into a grid with points at the grid intersections. Then special off grid points like items located on the site like power poles, corners of buildings - etc. That is what thier csv file is created from. If you create a csv file based on arbitrary points made from contour lines, this may be harder to create in the field. (May not be true for 3d computer controlled equipment. ????)
Obviously you created your Revit topo from an existing csv file. Then you added new points to modify that. Could it be that you only have to edit that existing file with your new points? ... and deleting some existing points? That may be an easier process.
I do see some possibilities useg dynamo but you would need to understand that.
Edited on: Tue, Jul 18, 2023 at 8:18:24 AM
I'm happy with the essay I recently finished writing with Writer24. They really provide the greatest service in the business, in fact. Additionally, their writers are quite competent and gifted. They nearly missed my deadline while still turning in a well written and thoroughly researched article. Their commitment to client happiness is what most struck me. They immediately made the changes I requested after responding to me. They are your finest option if you're searching for a trustworthy essay writing service that produces excellent work. I heartily urge anyone in need of academic support to take advantage of their services.
Toposurface - CSV import to shared coordinates |
Thu, Aug 22, 2013 at 2:59:54 PM
Using Survey Data to create a toposurface |
Mon, Oct 4, 2010 at 2:23:28 PM
Exporting Parameters to CSV or TXT |
Sat, Nov 4, 2006 at 8:53:00 PM
Reading "Points File" to build a toposurface |
Thu, May 3, 2007 at 2:42:29 PM
Toposurface and Floor Elevations not matching |
Wed, Mar 2, 2011 at 5:27:07 PM
Members: | 1995082 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
