63 Users Online (62 Members):
Forums >> Revit Systems >> Technical Support >> INO: Parametric Light Switch Family
0 Posts No Rating |
I have been on the hunt for a parametric light switch family that will allow for proper quantity take-offs for an electrician. I need a family that has an electrical box/gang box option from single (1) through quad (4) AND has the ability to set the individal switches inside the box to certain types (single pole, 3-way, dimmer, etc.) The intended outcome is to be able to set the box to the correct number of switches in it and then determine the type of switch for each on inside the box so that when a switch schedule is made it can produce the number of 1-gang/2-gang/3-gang/4-gang boxes in the project as well as a count for the number of regular/3-way/dimmer/etc. switches.
If anyone has a link or any idea how to build this family, any help would be greatly appreciated!
line to connect light switch to light fixture |
Wed, Mar 10, 2004 at 12:56:35 PM
Light switches |
Mon, Sep 22, 2014 at 1:04:57 PM
I can't assign a switch ID to a switch |
Wed, Dec 9, 2020 at 5:42:46 PM
Electrical-Symbol for Emergency Light |
Fri, Dec 27, 2013 at 7:20:00 AM
Switch ID Grayed out in Revit MEP |
Tue, Feb 26, 2013 at 11:33:36 AM
Members: | 1999855 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
