164 Users Online (163 Members):
Forums >> Revit Building >> Technical Support >> Adding thickness to topo surface???
Is there a way to add thickness to the topo in a model created in Revit architecture? I'd like to be abe revolve the model without seeing basement walls etc. which are below the surface.
Thanks!
I wrote this up in 2013: Make sure your topography extends beyond what you want to show, then create a section box inside of that and to the limits of what you want. Now, turn the section box on in your 3d view.
Topo Cut Line thickness |
Tue, Feb 14, 2012 at 10:49:24 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Deleted Topo Surface |
Fri, Apr 2, 2010 at 3:54:58 PM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
placing a street, vegetation and barrier or railing on topo surface |
Tue, Jan 17, 2017 at 5:47:40 AM
Members: | 1995254 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
