50 Users Online (48 Members):
Forums >> General Discussion >> Revit Project Management >> My model info just vanished, when I synched model
I've been working on model with one other person, I just synched it and model info vanished. I calle up local model and it looks fine, I used it to make a central model and as soon as I did it the model information dissappeared again.
Help.
Have you communicated with the other user?
You need to make sure you have a process where both of you are working on local files, not the central. And when a new central file is needed, the other user has to have exited the file and you update your local. Then when you save it, I suggest you do a save as and give it a new name ... like xxx (file name) + date (Month+day). Then each of you create a new local file from that central. Your local file should be saved on your system.
site info with the 3D model querie... |
Wed, Jun 13, 2007 at 11:42:18 PM
Model Linking Multitasking |
Fri, Oct 17, 2008 at 2:11:00 PM
Importing .dwg Details - Model Space vs. Paper Space |
Wed, Aug 9, 2006 at 5:37:45 PM
superimposing model on a photo or adding background to a model |
Sat, Nov 29, 2008 at 1:40:22 AM
Property lines cause drawing to disappear |
Wed, Mar 31, 2010 at 1:12:19 AM
Members: | 2000395 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
