66 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e
0 Posts No Rating |
Hi!
I use often ''door openings'' in order to make ....... openings on walls. My problem is that I use the same drawing in different scales. For example 1:50 and 1:100 where the dasced lines on the openings are like they should (not so much already at 1:100) but on 1:400 there is only one line and nobody understand if there is an opening there. Is there a way to change this behaviour?
The photos are from the same drawing at 1:50, 1:100 and 1:400 scale.
Thank you.
Edited on: Thu, Jun 3, 2021 at 3:02:43 AM
Revit has two linetype categories, model and detail.
Because model lines will scale to meet the view scale, dashed lines become a problem. As the scale gets smaller, the dash and no-line spaces become smaller and smaller until there is no longer a dash, just a line.
Detail lines will always be the same size in 'paper space'. If the space between dashes is actually 1/16" at 1-20 scale when measured on the print, it will still measure 1/16" in a 1-100 view.
0 Posts No Rating |
Thank you.
Hi WWHub,
This issue always bothers me.
In a family, all sybolic lines are Model lines.
How can I create a Detail line in a family? Which will be presented correctly in any scale?
Edited on: Tue, Jun 8, 2021 at 1:09:16 PM
In families, you can convert symbolic lines to model lines, and vice-versa. In a family, a symbolic line is only visible when the family is viewed from a specific direction. A model line in a family will be visible in all views of the family.
0 Posts No Rating |
Thank you!
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
'Door' Won't Load into Project |
Tue, Sep 28, 2010 at 7:11:37 PM
'Out of Memory' pop up |
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
Sheet 'X' of 'Total Number of Sheets' |
Wed, Jun 5, 2013 at 4:39:34 PM
Members: | 2000355 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
