71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Default Level of Template
I have created several templates, and suddenly one of them change the default level to 2nd floor. When I need to place a new architectural wall, it alway on the 2nd level, all other templates are still starting on the 1st level. It bothers me a lot.
Please help!
2020.1.
Edited on: Thu, May 6, 2021 at 11:32:43 AM
Templates do not change themselves, they are as they were created or modified by someone.
So, edit the template to what you want.
I am assuming you are talking about if you draw a wall in 3D then the base constraint is defaulting to Level 2? When drawing in a plan view the base constraint should be defaulting to the associated level.
I would check to make sure the plan views are named according to their base constraints.
Other than that you could go to an elevation/section and then move the level 2 down to the level 1 location and vice versa and then rename them correctly.
Underlay using construction template on 2012 version |
Thu, Nov 28, 2013 at 1:07:12 PM
View Template Object Visibility Problem |
Sat, Feb 26, 2011 at 2:53:16 PM
Changing .rte template midstream |
Thu, Feb 14, 2008 at 1:03:47 PM
metric template |
Mon, Apr 5, 2010 at 7:04:51 AM
recit 2012 default template link - Rmy |
Mon, Mar 3, 2014 at 7:50:02 AM
Members: | 2000305 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
