52 Users Online (51 Members):
Forums >> Revit Structure >> Technical Support >> Aligning family in a project
0 Posts No Rating |
I have created a clamp family, the clamps can be at varying heights and I would like to insert into a project and use the align command to control the heights of the clamps instead of say using a instance parameter is this possible?
I can only get the whole family to move up and down using the align I would like to align each clamp at different levels if possible?
Revit 2014 user |
You say the whole family moves up / down with the clamp. From that I assume you mean the family must be hung from the structure above and you want just the clamp portion to move. You still need an instance parameter with the family hosted to the structure above and the instanhce controlling the drop down of the clamp.
0 Posts No Rating |
I have instances parameters but when I use the align is moving the whole family up and down maybe because I am using a nested family in the family?
Revit 2014 user |
Did you make sure the dimensions for the instance parameters are attached to the reference planes and not other objects?
Self aligning text in a family |
Thu, Mar 25, 2010 at 10:50:38 AM
Drawing length of family in project? |
Thu, Jul 10, 2008 at 7:00:32 PM
Adding / Aligning Legends to multiple sheets |
Fri, Oct 17, 2014 at 9:03:43 AM
ALIGNING ANGLED FAMILY TO THE HORIZONTAL REFERENCE LINE |
Wed, Sep 10, 2014 at 7:31:57 PM
Aligning Grout Lines in Render Materials |
Fri, Dec 16, 2011 at 6:47:21 AM
Members: | 1999839 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
