60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Parallel sections show up in an elevation view
Wed, Nov 18, 2020 at 9:54:58 AM | Parallel sections show up in an elevation view
glenlake
3.5 Stars: 3 Votes
Hi everyone, is there a way to deit Section type property  (it is not a Detail section) not to have them seen in an Elevation views? For callout type, there is no NONE option. Please see the image
Thanks a lot
Wed, Nov 18, 2020 at 3:30:14 PM | Parallel sections show up in an elevation view
3.5 Stars: 391 Votes
I'm lost.  What is "...deit Section"?
I see detail callouts and a vertical section callout.
Wed, Nov 18, 2020 at 6:55:53 PM | Parallel sections show up in an elevation view
glenlake
3.5 Stars: 3 Votes
Sorry i was interrupted by recaptca when typing.
The problem is that i draw these sections (which we see as callouts) in plan as Sections.Not Detail, but just sections. There is only one Section type in the project. Why do i see these sections as callouts?
Much oblidged
Thu, Nov 19, 2020 at 7:53:58 AM | Parallel sections show up in an elevation view
For a detail callout, you can specify whether its callout tag displays in the parent view only or displays in the parent view and intersecting views.
Thu, Nov 19, 2020 at 12:20:32 PM | Parallel sections show up in an elevation view
glenlake
3.5 Stars: 3 Votes
I have drawn these things in plan as Sections. I don't understand why they are visible in a parallel section/elevation view as callouts.
Fri, Nov 20, 2020 at 8:44:48 AM | Parallel sections show up in an elevation view
I don't have Revit here.  Click on one of those bubbles you see in elevation and let us see what that is in the view properties.
Fri, Nov 20, 2020 at 10:31:11 AM | Parallel sections show up in an elevation view
glenlake
3.5 Stars: 3 Votes
Please see the images
Fri, Nov 20, 2020 at 10:40:42 AM | Parallel sections show up in an elevation view
glenlake
3.5 Stars: 3 Votes
I see these "callout like sections" in some parallel sections, but in some i don't see them. Both of these parallel sections are intersected by view range of "callout like sections" . Please see properties of one which shows these 'callout like sections"
Fri, Nov 20, 2020 at 10:42:36 AM | Parallel sections show up in an elevation view
So I take it that this is one of those two larger bubbles.
For all to know - what Revit issue and what updates?
Fri, Nov 20, 2020 at 10:52:40 AM | Parallel sections show up in an elevation view
Glen - show me the elevation on the right that is perpidicular to this view.  I want t\o see these 'sections' there
Fri, Nov 20, 2020 at 12:17:35 PM | Parallel sections show up in an elevation view
#11
glenlake
3.5 Stars: 3 Votes
It is a section, the same type. Elevation shows the same thing
161042_North_View_Section_Instance_Properties.png161042_View_from_the_North_Section.png
Fri, Nov 20, 2020 at 1:36:07 PM | Parallel sections show up in an elevation view
#12
Another friend told me you used the callout tool, but selected the section type. When you place a callout you can tellit that this is a elevation callout, detail callout or section callout
either that or they placed a section in a perp view and it's showing up here as a callout
Fri, Nov 20, 2020 at 6:05:45 PM | Parallel sections show up in an elevation view
#13
glenlake
3.5 Stars: 3 Votes
No.
I opened a plan view, selected a Section tool (Building Section type), and draw a section.
Opend a parallel section and saw a callout.
Sun, Nov 22, 2020 at 12:07:40 PM | Parallel sections show up in an elevation view
#14
glenlake
3.5 Stars: 3 Votes
Sorry, what is a perp view? Maybe it is the reason.
Revit Architecture 2012 - Column Grids not Parallel to View will not show up
Wed, Nov 23, 2011 at 1:27:06 PM
Revit 2013 - realign elevation view parallel to wall
Tue, Oct 16, 2012 at 3:07:52 PM
creating a elevation view on a non parallel wall
Wed, May 26, 2010 at 10:06:58 AM
Defining elevation views parallel to a reference plane
Sun, Mar 5, 2006 at 2:37:41 PM
Callout/ Section/ Elevation marks on parallel plans
Wed, Feb 22, 2006 at 5:56:30 PM
Page generation time: 1.5713
