65 Users Online (63 Members):
Forums >> Community >> Newbies >> green transparent wall when in realistic mode
Hi. I'm a Revit student and this is my first building.
I have a couple of walls that are behaving this way - the common thread is that they have all had their profile's edited to reach a roof on a higher level. Any thoughts please?
Check the materials.
Check if the wall has been painted a different material.
Check if wall has been joined to something else as it may be using the material finish of the joined object. Unjoin them.
Profile edit wouldn't be the reason for a material finish issue.
Thanks
I couldn't see that any of those options were contributing, however, I have been able to paint over it which works out fine.
Appreciate your time.
1 Posts No Rating |
Hi Camille89,
I didn't see a snippet or pic where you show what is happening. Be sure to upload a pic of the issue you are having then outline the problem and be as specific as you can. Big thing is I don't see a pic. Hope this helps. Daniel
daniel with cdb-university.com
on youtube at
https://www.youtube.com/channel/UCJwS8p9S1Zyn2pqKwDsIs_Q?view_as=subscriber
CDB-University Learning Revit
cdb-university.com
https://www.youtube.com/channel/UCJwS8p9S1Zyn2pqKwDsIs_Q?view_as=subscriber |
How to make my views in 3D more realistic.. |
Fri, Oct 9, 2015 at 7:36:22 AM
Filled region not showing in elevation realistic mode |
Wed, May 15, 2013 at 1:55:02 AM
Having problem with realistic style mode in Revit Architecture 2012 |
Wed, Jun 22, 2011 at 8:04:36 AM
Surfaces not shown in realistic mode. |
Fri, Mar 11, 2011 at 12:59:06 PM
Glazing Transparency in Realistic View |
Wed, Jun 6, 2012 at 8:51:53 AM
Members: | 1999865 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
