60 Users Online (59 Members):
Forums >> Revit Systems >> Technical Support >> Change which fitting family is automatically applied while connecting duct?
I'm working with ductwork in a model. There are several fitting families in the model. (I'm connecting branches to risers.)
How can I choose which fitting family is automatically used when I connect the ductwork?
Right now, the incorrect fitting family appears when I connect the ducts and I have to manually choose the fitting I want from the list. I want to set it up, so the correct fitting family is the default, that appears when I connect the ducts.
Thank you for your help. I appreciate your time.
https://revitmep.blogspot.com/2008/09/setting-up-default-fittings-to-be-used.html
Perfect! Thank you WWHub.
Duct Fitting Issue |
Tue, Apr 1, 2014 at 1:16:35 PM
Rectangular Flanged Square Duct Fitting 45 Degree |
Mon, Jun 17, 2013 at 4:46:32 AM
eccentric fitting for rectangular duct |
Wed, Apr 15, 2015 at 12:13:18 PM
Custom duct tee |
Tue, Jul 5, 2011 at 12:50:11 PM
Duct Systems. |
Mon, Aug 5, 2013 at 7:48:16 AM
Members: | 1999746 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
