75 Users Online (73 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit 2020 - Stair Landing Supports
148 Posts No Rating |
Greetings,
I am trying to find a way to adjust the stair landings such that the supports are below the landing. When I adjust the height/offset to be below the landing, the landing will not continue over the supports. Is this controllable, or must I add additional steel (or details components) to achieve the look. The attached image had detail components ...
The ability to make this a part of the support or landing would be the deisred outcome.
thanks in advance.Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
The standard metal pan stair tht is typically used in our area looks like this:
The stair stringer channel frames aroud the back and sides of the landing forming a kick. There is an additional angle and framing for the landing pan.
But all of that is usually taken care of in the shop drawings.
Edited on: Tue, Jun 30, 2020 at 3:33:51 PM
Thanks for your response WW. we usually do stair landing similarly. But not this time. The designer doesn't want the kick.
As described, I am hoping to create a landing or support style that will deliver what my attached image shows ... the supports entirely below the landing.
Revit allows the support to be below, but the landing stops at the edge of the support.
Please check the image, I had to sketch in the supports. Can Revit do this?
Ian Shafer
Use seperate runs and do a floor for the landing.
Editing Profile of Stair Landing |
Mon, Mar 3, 2014 at 2:36:37 PM
Stair to landing connection shown incorrect in section |
Mon, Sep 20, 2010 at 11:40:14 AM
Starting a Rail on the stair landing. |
Thu, Dec 19, 2013 at 3:01:59 PM
How to get a stair to have a landing with runs on both sides? |
Sun, May 22, 2011 at 2:56:32 PM
Stair Landing Height Problem |
Fri, May 13, 2016 at 12:33:14 PM
Members: | 1999288 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
