69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Tubelite Curtainwall
Was wondering if anyone has tried using the Tubelite Curtainwall system? I loaded it into my project and it works great except now it won't host the sliding door panel I downloaded from this site. It only will let me put in a glass panel where the doors where.
Revit 2020
Is it a funny shape? Like non-orthogonal? Maybe you have some curtain gridlines in it?
It is the regular tublelite profiles. No gridlines that I see. I found a work around and placed a wall in the opening and then inserted the door.
Does no one use the Tubelite curtainwall in their drawings? Was wondering how close to accurate you draw your curtainwalls? My boss likes for us to show the 1/2" shim space on the bottom and top of the wall so I am sitting the wall 1/2" off the levels but now my doors are not showing the correct height in the schedule?
UPDATE: I went in and formatted the door schedule column to round to the nearest inch and that fixed the problem. HOpe this can help someone else!
Edited on: Tue, May 26, 2020 at 2:05:56 PM
Now I am trying to figure out the corner mullions. None of the BIM profiles match the AutoCAD profiles! Surerly someone has used the Tubelite system?
Curtainwall edit profile |
Fri, Jun 12, 2020 at 7:48:21 AM
Converting curtainwall into wireframe |
Wed, Jun 13, 2012 at 2:08:44 PM
12
Revit 2013 - Can't Use Align Tool on Edge of Curtainwall |
Fri, Oct 26, 2012 at 11:45:05 AM
Custom Curtainwall Tag from View Tag |
Tue, Feb 26, 2008 at 9:17:54 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing |
Mon, Jan 19, 2015 at 7:41:36 AM
Members: | 1999872 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
