80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Hardware >> WIndows 10 Update 1909 Revit does not work
Mon, Feb 17, 2020 at 3:22:48 AM | WIndows 10 Update 1909 Revit does not work
lukaskoh
Windows 10 forced me to update 1909. After it revoked my license for Revit 2020. A similar thing happened to a friend. He found instructions on some forums that he had to install C ++ and delete something in H-keees. But he didn't know what to do anymore. Did something happen to you too?
Thu, Apr 23, 2020 at 5:31:11 PM | WIndows 10 Update 1909 Revit does not work
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Yep, some windows C++ thing needed reinstalling.
Sun, Mar 26, 2023 at 11:36:15 PM | WIndows 10 Update 1909 Revit does not work
daimmalik
It's possible that there may be compatibility issues between Windows 10 Update 1909 and the version of Revit you are using. This can sometimes happen when software is not updated to work with the latest version of the operating system. Know more about windows from instantlobby.com.
Here are a few things you can try to troubleshoot the issue:
Check for Revit updates: Check to see if there are any updates available for Revit that may be compatible with Windows 10 Update 1909. If there are, download and install the updates to see if it resolves the issue.
Reinstall Revit: Try uninstalling and reinstalling Revit on your computer. This can sometimes fix compatibility issues between the software and the operating system.
Run in compatibility mode: Try running Revit in compatibility mode for an earlier version of Windows, such as Windows 8 or Windows 7. To do this, right-click on the Revit shortcut or executable file, select Properties, and then click on the Compatibility tab. From there, you can select an earlier version of Windows to run the program in compatibility mode.
Contact Autodesk support: If none of the above solutions work, contact Autodesk support for further assistance. They may be able to provide more specific advice or help you troubleshoot the issue.
It's worth noting that updating your operating system to the latest version may also help resolve compatibility issues. If you're unable to get Revit to work on Windows 10 Update 1909, you may want to consider updating to a more recent version of Windows 10.
Windows 8.1 Update / Fix?
Wed, Oct 29, 2014 at 10:01:02 AM
Does Revit 2009/2010 work properly to on Windows 7
Thu, Jun 3, 2010 at 4:25:04 AM
12
walls disassociated with mass - can't update walls
Fri, Nov 2, 2012 at 10:51:18 AM
UPDATE 1
Tue, Dec 4, 2012 at 8:21:12 PM
Revit 2017 in windows 10
Tue, Jul 26, 2016 at 12:57:10 PM
Page generation time: 2.2390
