61 Users Online (60 Members):
Forums >> Revit Building >> Tips & Tricks >> Model view section cut refer to a drafting view
On a drafting view, I can place a section cut to create a drafting view section. Then I can place that section view on a sheet and populate the correct reference.
Does any way that I can place a section cut on a model view, such as a floor plan, and refer to a drafting view such as a “Floor Transition” detail?
The HELP always Helps!
http://help.autodesk.com/view/RVT/2016/ENU/?caas=caas%2Fscreencast%2FMain%2FDetails%2F31b698a1-0b25-4877-9f86-9884f8ea66e8.html
Hi WWHub,
Thanks for your response.
However, my question was that I would like to have a section mark with a tail instead of the rectangular bubble. Which allows me to refer to a drafting view to show a floor material transition on the plan view for example.
The view family is a system family, if the Revit does not have that, then I would like to know if I can create a view family to achieve what I need.
Thanks again!
No, I answered your original question, how tyo refer to a drafting view in a floor plan section. Now you are asking something completely different and I do not understand the question. It seems to be modifying the tail on a section cut which is up to you.
https://www.revitcity.com/forums.php?action=viewthread&thread_id=4345
I got the answer, it’s simple, and I don’t know why I have struggled a while.
1. Under the View tab, in Create panel, click “Section”; then check the box “Reference Other View”. Then you can use
2. the section cut. In Project Browser, under Drafting Views, a new drafting view “Section 1” will be shown.
Drag that view and place onto a sheet. That’s it, just like a callout.
Edited on: Wed, Nov 13, 2019 at 8:29:40 AM
Eactly what I referenced you to in my original answer.
Trouble copying detail items from Section View to Drafting View |
Mon, Aug 19, 2013 at 1:08:05 PM
drafting view types? |
Fri, Nov 11, 2011 at 2:44:00 PM
drafting view from model view |
Mon, Jun 29, 2015 at 7:27:31 AM
Referring section tags to specific views |
Wed, Feb 16, 2011 at 1:58:57 PM
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
Members: | 1998879 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
