58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DWG sheets to RVT
Fri, May 10, 2019 at 4:31:05 AM | DWG sheets to RVT
Olzhas
Hello!
I drew handrails in dwg model space and I have 4  paper space sheets which I want to add to my revit sheets. Linking CAD adds everything in the model space, but what I want is to searately insert the sheets I prepared in dwg. I tried to convert them to pdf but don't know how to  add pdf to revit. Can you please advise on how to deal with such problems? Thank you
Mon, May 13, 2019 at 6:43:07 AM | DWG sheets to RVT
tim123
4 Stars: 19 Votes
You can insert the PDFs into AutoCAD and then import that into Revit.
If you have Revit 2020, you can insert the PDF directly into Revit.
But why do you set up the sheets in AutoCAD if you need them in Revit?  Rather create similar sheets in Revit and then insert your CAD details as Detail items into a drafting view.
Fri, May 17, 2019 at 7:02:39 AM | DWG sheets to RVT
Olzhas
Thanks for the advise. I converted one sheet into pdf and inserted it in AutoCAD but when I insert this dwg to Revit it does not work. I am using Revit 2019 so can't directly insert pdf.
Fri, May 31, 2019 at 4:34:11 AM | DWG sheets to RVT
koleman
Are then your Sheets just 2D elements and not families with parameters?
Fri, May 31, 2019 at 4:39:11 AM | DWG sheets to RVT
Olzhas
Some of my sheets are from AutoCad which I insert in Legends first and then into the pages. Yes, they are 2D elements. I converted those drawings into jpeg and then inserted in revit. Not really a BIM approach
Fri, May 31, 2019 at 5:17:09 AM | DWG sheets to RVT
koleman
I guess it´s easier if you convert your autoCAD Sheet into a revit "Sheet" Family and link your CAD in drafting sheet. You have just advantage out of it.
Fri, Jun 7, 2019 at 6:14:28 AM | DWG sheets to RVT
Olzhas
Could you please clarify how to do this? How to convert cad sheet into revit sheet family? I have attached a snap of my paper space view.
P.S. Inserting the sheet as jpeg didn't work as planned as the quality of lines became poor.
Fri, Jun 7, 2019 at 10:50:04 AM | DWG sheets to RVT
3.5 Stars: 391 Votes
Clarify your question.  Do you really want a CAD sheet or do you want some views from a CAD sheet?
Sun, Jun 9, 2019 at 10:57:52 PM | DWG sheets to RVT
Olzhas
My question is related to the suggestion by previous user (Koleman).
I want to transfer into rvt what I drew in CAD, particularly what is shown in paper space (the sheet with multiple viewports with different scales). Otherwise I will have to rescale things in model space and they no longer will be 1:1 and insert as CAD into rvt which is not very efficient. Why can't revit simply export a sheet which is already composed in paper space.
exporting to dwg
Wed, Aug 18, 2010 at 5:10:21 AM
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:27:59 AM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:27 PM
Sheets on DWG exoprts
Wed, Mar 20, 2013 at 7:36:01 AM
Page generation time: 0.4325
