62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> IFC import to Revit '17, materials all grey
Mon, Apr 1, 2019 at 6:58:31 AM | IFC import to Revit '17, materials all grey
bradipetto
Hi all,
My name is Fred, I'm not a Revit expert, I'm pretty much self taught.
I'm trying to work on a project that somebody else generated on Archicad. My task is to just make the render out of this project which is already finished.
I received a IFC file of the project that I can open on my Revit 2017, I can see the projects clearly with no defects, but I don't seem to be able to modify anything on it, like I said, I just need to render this project, so I don't need to change details and or dimensions. But still, it's kind of odd that I can't do almost anything at all with the elements of this small project.
The only information I need to be able to see is the materials that this guy assigned to all the objects. But when I go and render everything is plain grey, including all the windows, they're all just grey surfaces.
I looked around the forums, tried some options I read, such as saving it as .rvt and open it up again, but still, I seem to able to only change very little in the parameters. And even if I'm able to change the "material/finishes" in some of this "anonymous" object that compose the project, everything will still look plain grey when rendering.
When I accepted this rendering job I thought it would have been a relatively easy task to just work on the renders on somebody else Archicad work, but it doesn't look that simple anymore.
Am I doing something wrong on my side when importing this file? Or is the problem perhaps at the other end? I already told the Archicad guy about this issue and he sent another IFC that, he said, "should now work", but I don't see anything different...
Thanks in advance to all the community for the help.
Regards,
Fred
Mon, Apr 1, 2019 at 4:14:34 PM | IFC import to Revit '17, materials all grey
oldtexas
check phase.. all existing phase families render gray.
Sat, Apr 6, 2019 at 5:01:59 AM | oldtexas
bradipetto
Quoting oldtexas from 2019-04-01 16:14:34
Hi Oldtexas,
Thanks for your reply. Can I ask you some directions on this?
It looks like all the objects are all on Phase 3 on this project that i'm importing and the Phase filter is set to Show Complete.
From here, what do I need to do in order to be able to "see" and render the objects that are part of this project with the materials and properties that the guy on Archicad assigned to them?
Fred
Sat, Apr 6, 2019 at 5:08:21 AM | IFC import to Revit '17, materials all grey
bradipetto
I'm also starting to tthink that maybe the problem is at the other end, but not knowing myself Archicad at all I don't even know what to ask about the IFC export process to this other guy?
I have seen screenshot of renders he had done on archicad on this same project so the materials are there, but perhaps they're not on the exported IFC?
Fred
Sat, Apr 6, 2019 at 5:08:24 AM | IFC import to Revit '17, materials all grey
bradipetto
Fred
No Import - Maximum size of IFC imports?
Sun, Jul 10, 2016 at 6:56:30 AM
Revit export/import to IFC - ceilings and floors (ifccovering)
Mon, Jul 28, 2014 at 3:22:58 PM
Revit to Ifc to Third Party BIM Viewer
Tue, Dec 11, 2018 at 12:36:03 PM
Revit Family Export to IFC
Fri, Nov 29, 2013 at 4:29:41 PM
IFC import intoRST2010?..
Fri, Mar 26, 2010 at 2:07:17 PM
Page generation time: 3.9911
