76 Users Online (74 Members):
Forums >> Revit Systems >> Technical Support >> open families starts in wrong path
Hi!
When I want to open system families the program always opens in the wrong path. I have to go to the library manually all the time.
It should open here: C:\ProgramData\Autodesk\RVT 2018\Libraries
but instead it always opens here: C:\Program Files\Autodesk\Revit 2018.
Where can I change the path to open families in the right place?
Thanks.
Learn to use your help.
http://help.autodesk.com/view/RVT/2016/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FHow-to-change-the-default-file-location-for-families-in-Revit.html
Thank you very much. I had found it by myself in the meantime.
Need file location help for open command path |
Sat, Sep 11, 2010 at 5:27:16 PM
Column sweep |
Mon, Jul 2, 2007 at 10:05:20 AM
stair path to show full length of stair REVIT 2015 |
Thu, May 28, 2015 at 3:59:54 PM
Controlling Visiblilty Of Multiple Families |
Sun, Nov 4, 2012 at 10:16:48 AM
Saved path keep changing - won't create local alias |
Tue, Sep 20, 2011 at 7:46:23 PM
Members: | 1999305 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
