66 Users Online (65 Members):
Forums >> Community >> The Studio >> Which version to choose
0 Posts No Rating |
Hello. Due to some reasons I've decided to Chief Architect to Revit. But I'm completely confused with different versions of Revit... My job is to redesign customer's houses. What I do is 3d scan building upload 3d scan to the software (It was Chief Architect and it will be Revit), Then based on this data make a new design for the building. As I know Revit has strong analitical instruments for physical characteristics of the building so I can calculate what to change and what not. Which Revit version will be the best choice for my workflow? To make 3d scans I use Artec Studio with Artec scanners (I provide the links so you can read how it export data).
Use the latest version of REVIT. Either 2018 or 2019.
0 Posts No Rating |
Thank you.
Revit is updated yearly now. Once you upgrade your model/project to a new version, the file cannot be downgraded to an older version. This is important to understand. Once you upgrade - YOU CAN NOT GO BACK.
Deciding on which version is an important decision you should make with your consultants involved. If there are no consultants - then I always use the most current version of Revit, which is currently 2019.
Edited on: Tue, Jun 5, 2018 at 10:15:17 AM
revit latest version cannot be save to a lower version |
Wed, Apr 27, 2011 at 10:00:25 AM
Insert Revit plan into Word |
Mon, Sep 18, 2006 at 8:33:46 AM
Can't choose generic walls |
Mon, Nov 7, 2011 at 2:59:18 PM
File in Student Version transfers to Professional Version |
Mon, Jul 26, 2010 at 12:06:11 PM
Problem opening "component" version 9.1 in revit version 9.1 |
Fri, Jun 15, 2007 at 8:25:21 AM
Members: | 1999786 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
