75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> component wont host to wall properly
So Im using this hand sink.
it looks good in the family editor, but when you host it to a wall in my project, it embeds into it. and changes shape slightly.
see pic.
how do I fix this?! why does this happen. One sink is going to make me spend 2 hours trying to fix it...
I opened your model file. FYI its saved in a 2019 "Pre Release" format... When i saved back - it's now the new 2019 format.
so. here's what i did. I dragged your wall. half the stuff in the family was using it as a reference plane and half stayed put. Since there are 0 parameters set up, I dissociated all the parts with their work planes. If things were parametric you don't do this - mainly because you lock your planes and set it up smart. this family was not done that way.
My steps:
- Disassociate all parts from their work planes (you can check it by dragging the wall in the family when no parts move)
- Group all the model items in the family
- Add a reference line (not plane) at the back of the sink inside the group
- Unpin all reference planes
- Deleted unnecessary refence planes (for tidiness)
- Lock the two required reference planes (you'll know because you can not delete them) to the face of the wall.
- Lock the reference line you added in the group to the face of the reference planes
Bam, it works.
I used to think that the reference planes always drove insertion points (when marked origin) - but when it's wall mounted - it's the face of wall. and when I lock my reference planes to face of wall, it is always flush.
Edited on: Wed, Apr 25, 2018 at 1:54:48 PM
THanks a lot! Ill try it tomorrow.
I did DL it from this site, or some other (can't remember)
THanks again!
why wont object pick new host? |
Tue, Nov 8, 2011 at 3:23:56 PM
Host wall |
Thu, Sep 1, 2005 at 5:10:36 PM
Host wall thickness, in door schedule. |
Fri, May 31, 2019 at 4:26:18 AM
Railing wont host to stair created in design option |
Mon, Oct 24, 2011 at 3:54:39 PM
Beam wont show, Spot slope not Accurate and Twin windows |
Tue, Jul 14, 2015 at 12:41:45 PM
Members: | 1999888 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
