62 Users Online (61 Members):
Forums >> Revit Structure >> Technical Support >> stacked structural concrete columns
How do I create a stacked concrete column where the column size/shape changes at each floor as it goes up the building?
I have been placing a new column at each floor but the boss wants it to be one column with one tag.
Thank you
Jennifer
Jennifer Arnold
jennifer@selectstructural.com |
what i would do is to group them and turn each stack in a single object, so if you move one in a level, all other segments in the other levels, also move. And use multi cathegory tag to give it a name.
yes i have done that before but it made a mess when they started changes sizes and shapes on me. also i believe it splits the grouped column up in the graphical column schedule.
Thank you!!
Jennifer Arnold
Concrete Columns and Beams cuts through wall... |
Mon, Feb 4, 2013 at 8:10:15 AM
Concrete columns behaviour before and after placing concrete beams |
Tue, Apr 1, 2014 at 1:58:43 AM
Beams won't intersect or close-up to Structural Columns. Solution ? |
Tue, Oct 18, 2016 at 2:01:11 PM
structural wall VS structural columns |
Tue, Apr 26, 2016 at 3:49:39 PM
Cut Pattern - Timber Columns in plan views to black ? |
Tue, Mar 18, 2014 at 7:41:46 PM
Members: | 2005506 | Objects: | 22910 | Forum Posts: | 152183 | Job Listings: | 3 |
