65 Users Online (63 Members):
Forums >> Workflow & Implementation >> Worksets >> Annotations Gray'd out?
Hey All,
Having an issue (hopefully there is a simple solution). Typically we don't use many worksets for our projects but this is a stadium with a lot of seating so it's on a separate workset...
For the most part I want this workset to be "Inactive" and gray but when my "Gray inactive Worksets" is turned on all my Annotations are also grayed out... WHY?
Can i get my annotations back to normal??
Thanks in advance!
i think the better process for what you need is to create a view filter for that workset and set it to halftone and then apply it to the desired view templates
Not all annotations are greyed out - correct? Only those tyed to the inactive workset like tags.
Elnazer2 has the proper answer.
You say you have a lot of seats. Making a workset inactive doesn't improve efficiency of operation, the tool for that is to unload that workset.
Thanks by the way guys. I guess i was trying do the wrong thing. I wanted the workset to be turned off for efficiency but still show up as "greyed out" or "transparent" but this is not a possibility.
I just ended up turning off the workset when not required and turning back on to create PDF's or prints.
Thanks again..
Can't load annotations |
Wed, Jun 27, 2007 at 4:23:05 PM
Gray walls |
Tue, Jun 13, 2006 at 1:07:37 PM
sections - level annotations |
Mon, Sep 5, 2005 at 7:33:03 PM
Doors make a gray shadow in Sections |
Wed, Apr 7, 2004 at 10:39:43 AM
Rendering coming out gray |
Wed, Jul 19, 2006 at 5:49:21 PM
Members: | 2000339 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
