52 Users Online (51 Members):
Forums >> Revit Structure >> Technical Support >> Cutting wall end with in-place void - Revit 2018
Hi, I can't cut a wall end to a certain angle using a void extrusion, in Revit 2018. I've tried in a new project, empty, just a wall from level 1 to 2, and an inplace family void extruded in the end of the wall as a 45 degree triangle. The error message says "Some Void Forms of this family do not cut anything and will be deleted. To make a Void Form cut something else use the Cut Geometry tool." I've tried making the void larger than the wall, smaller, longer, shorter... Always the same message. Thanks.
'To make a Void Form cut something else use the Cut Geometry tool' - do what the error message says before you exit void sketch mode.
The message pops when I try to finish the void make with the "OK" green mark.
First, the void actually has to intersect the solid, then do what pijpiwo writes.
The void intersects the wall, I can see in the 3d view. I follow Autodesk video step by step but when is time to finish, I get the error message... Is it a bug or am I missing something?
Reread what pijpiwo wrote ...." before you exit void sketch mode."
Yeaaahhh! Thanks a lot!
V. 2018 - cutting wall sweeps with void forms for stadium seating |
Thu, Jan 11, 2018 at 12:50:20 PM
Void Mass Not Cutting Divided Surface Mass |
Wed, Jan 31, 2018 at 10:19:21 AM
Wall Hosted Family cutting void into Wall |
Mon, Aug 23, 2010 at 3:58:59 PM
Diagonal End of Wall - Void + Cut Geometry not working |
Fri, Aug 30, 2013 at 3:25:08 AM
Wall void |
Wed, Jul 25, 2018 at 10:37:10 AM
Members: | 2048108 | Objects: | 23053 | Forum Posts: | 152305 | Job Listings: | 3 |
