67 Users Online (66 Members):
Forums >> Revit Structure >> Tips & Tricks >> Steel Framing_ Welded I section with different t_flange top and bottom
0 Posts No Rating |
I have found steel welded section with different b_top_flange & b_bottom_flange.
I see it is vere difficult to add a new parameter in the existing family to differ the thicknesses of the two flanges.
Is there any easy way ? Is there any family including these parameters? Or i must create a new family?
Thank you in advance!
You may be able to edit the family and add parameters to the sketch but I would create a new family or edit the existing and save as a new family.
0 Posts No Rating |
I tried to edi the existing family and save it as new, but for some reason the 2 flange thicknesses (top and bottom) are associated and locked together!
So when i inserted my new family in the project, i cound edit the added parameter, but the section was remaining the same!!!
Thank you very much!
Just adding a parameter does nothing. You have to edit the sketch in the family. Turn on the dimensions and you should find the dimension that controls the flange thickness.
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Baluster Top Offset Issue |
Tue, Jan 12, 2016 at 8:43:40 AM
flat channel top of steel |
Wed, Oct 26, 2011 at 2:13:55 PM
Top of Steel / Bottom of Deck Elevation using a Spot Elevation? |
Fri, Jan 21, 2011 at 2:04:46 PM
Top of Steel Level for rotated beams |
Wed, Sep 21, 2016 at 2:03:21 PM
Members: | 2000420 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
