75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> in place of 'model-in-place'
97 Posts No Rating |
Revit LT 2017
so, I've just started doing some work for a company that is using Revit LT, 2017. VERY happy to be using Revit again... (layoffs up here are a drag!)
But, to "decorate" a front gable of a house (for example drawing in a shadow band) I used to model in place the shadow band using named reference planes. Since Revit LT does not allow model in place, I'm wondering how others are doing such things as shadow bands and other artful decorations on a house.... like different window trims, shadow bands, tudor-style trims, etc.
Do people create families now for this kind of thing?
Sign me... Wondering... in the snowy north....
Thanks,
Susan
Just make families independent of Revit and load them in. A bit of a pfaff having to open them and load them back in everytime you need to adjust their size but it can be done. You could create them also with parameters to chamfer the corner positive or negative, adjust their length and profile options.Or use a wall sweep or wall reveal.
Thank you for answering... I'm sure that is how it would have to be done... making a family.... thanks, though. I'm sure that once I've created a loadable family... with angles and widths that would be parametric, it would simplify drawings in the future.... ha.
It's too bad that we can't use sweeps or reveals, as they do not "angle" they are only good for using vertically or horizontally.
Edited on: Mon, Jan 16, 2017 at 11:27:36 AM
Line based families are going to help you probably. There's going to be a learning curve in creating loadable families, but once you get good at it it will make doing subsequent projects go easily since you can reuse your rakes, eaves, soffits and facias.
Good luck and post some of the families that you make here!
'forms' not available in 'in place mass' or components.please help |
Fri, Aug 30, 2013 at 3:20:58 AM
Create a new family from a 'model in place' |
Tue, Jan 17, 2017 at 12:57:22 PM
Attatching an image to a 'Model in Place' mass |
Fri, Apr 27, 2012 at 9:36:34 AM
linked revit model disappears when I edit a floor or do an 'in place' model |
Mon, Dec 17, 2012 at 8:01:15 PM
Issue creating mass floor area schedule (mix of families & 'model in place' mass |
Thu, Sep 27, 2012 at 7:05:36 AM
Members: | 1999373 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
