43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Family 'Defines Origin' with nested families not working
Hi!
For some reason my nested family (attached) is loading into my project with an origin far away from the centre point of the modelled elements - making zoom extents,rotate and tagging in particular a real nightmare!
I've checked the reference planes in the host familiy and all the nested families and there are all set to 'Defines Origin' but still no luck.
Any ideas on possible reason for the issue would be much appreciated
Many thanks
G
Do you still have the origin ref. planes checkboxed to be the origin?
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
Yes, in the host familiy and all the nested families
Do you have CAD in this family? Get rid of it or modify it.
Yes, several of the families are simple imported DWGs - I will try removing the DWG elements, thanks
Well it wasn't any of the nested families that contained DWGs in the end - it was actually the taps from NBS National Bim Library (UK), https://www.nationalbimlibrary.com/. I copied all the extrusions from the taps familiy into a new familiy at that seems to solve the problem - many thanks for the help, no doubt will be back!
Nested Family won't lock to 2 ref planes/lines |
Fri, Jan 17, 2014 at 10:09:19 AM
Nested Family - problem with setting origin of loaded component (Revit 9) |
Fri, Aug 22, 2008 at 10:58:05 AM
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Acad Import - Origin to Origin |
Wed, Aug 1, 2007 at 5:57:25 PM
Constraining problems - sometimes they do, sometimes they don't |
Tue, May 19, 2009 at 2:04:02 PM
Members: | 2000388 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
